Re: [Dúvida] Upload video PS3
13 Mai 2010, 17:45 [#3]
PesLord Escreveu:Boas People!
Tenho uma dúvida. Como consigo passar um video de um jogo na Ps3 para o pc para ,por exemplo, querer fazer o upload no youtube viddler etc?!
É que não faço a minima mesmo!
pela experiencia que tenho na ps3 ( que ja é alguma ) acho que a unica maneira de o fazer é gravares com uma camara ou tlm o video, replay, etc. pondo-o a reproduzir e filmar a televisão
depois fazes upload onde quiseres apartir do teu pc ;)
26 Mai 2010, 12:45 [#9]
Encontrei isto na net, para uma resposta à minha pergunta:
It is quite easy if you have some extra hardware. The concept is simple: split the output signal from your PS3 and plug it into a recording device. Basically you get an HDMI splitter, then get a recorder, which could be your PC if you have a capture card (most people don't), or a standalone DVD recorder. Some other devices such as camcorders might be able to record from an external source as well. The most economic way to do this is with a DVD recorder which you can get on ebay for under $100. I don't know if thats withing your budget, if not then your best option is a well positioned camera in front of the TV
O que sugere ele aqui é ter duas ligações? á camera/pc à ps3?
26 Mai 2010, 12:51 [#10]
Outra:
For Hd it is a little more complicated, since no TV i have ever owned has had a Hd Video out. So, you would have to have a source selector with 2 Hd video out ports, one for he TV and one for the PC. So in order it goes from your ps3 to the source selector via HDMI or component then source selector( i say source selector but it will probably have to be a HD splitter) to TV and PC via HDMI and or component. Also you will have to have a video card in your pc that has a video input slot, most likely have to be aftermarket. Hope this clears it up a little
27 Jul 2010, 18:46 [#11]
PesLord Escreveu:Outra:
Se for um vídeo de FIFA, fazes o upload para os servers da EA e depois sacas, tem lá a opção download.
