And quite a detailed press release for PES 2013:
Quote:
PES 2013: INNOVATIONS AND IMPROVEMENTS
by PES-Team on 24/04/12
This extensive article tells you about all the new, extended and improved PES 2013 features.
The first PES 2013 trailer is online. Along with the video, we provide you, the PES community, with this extensive article, containing much information about what is new and improved in the 2013 edition of the Konami football game.
Many of the new features, extensions and improvements are based on your feedback, i.e. your critical and constructive comments as the PES community – on this official PES portal, on various PES fanpages on Facebook, and in long e-mails as well as in clearly verbalized YouTube video appeals. On top of that, we have got many answers on Twitter and statements of tens of thousands of participants that have shared their opinions.
All your feedback has been analyzed, processed and discussed with the PES 2013 developers in numerous meetings.
Control and animation of the goalkeeper, the sound ambience in the stadiums, the gameplay balance – these were, amongst other things, the points that have been talked about and criticized the most. Therefore, these elements will be improved and extended in PES 2013. Read more about it in the article below.
The new features and improvements in PES 2013 are based on the following three central components: PES FullControl, Player ID, and ProActive AI. We will explain what this exactly means in a moment.
1. PES FullControl (PES FC)
The term PES FullControl describes several new and improved features that give you even more control about the players and the ball in PES 2013.
Total Freedom of Control:
Pro Evolution Soccer introduced the concept of freedom of movement, the new ‘PES FC’ in PES 2013 goes further with total freedom over ball control.
Dynamic First Touch:
PES 2013 introduces subtle ways to receive the ball, from traps, gently lifting it past an attacker to run on to or a variety of other moves. First touch is everything and players can trap the ball using the R2 button, killing the speed of a well-hit pass and bringing it instantly under control, or using the momentum of the pass to turn a defender.
Full Manual Shooting and Full Manual Passing:
PES 2013 offers fully manual passing and for the first time ever manual shooting, allowing users to determine the height and power of each. Long low passes can be sent skimming across the pitch, while shooting the user has total control over where the shot is placed. Skill and precision are needed to master these, but passes can be made into open areas, allowing lone strikers to thrive, while offering an unrivalled variety in ways to score.
"Full Manual Shooting and Full Manual Passing: PES 2013 offers fully manual passing and for the first time ever manual shooting."
Dribbling:
The speed with which a player moves with the ball has been slowed in line with real matches, but using R2 allows players to add various styles to their close control. Players can vary the speed of their dribbling, and cushion the ball as they move freely within a 360-degree circle. The new system allows players to knock a ball past a player and collect it, nutmeg them, or hold up play by shielding the ball as team mates find space and make runs.
Full Manual One-Two:
Active one-two passes can be made, with the second player being moved in any direction), facilitating various tactical movements.
Response Defending:
Countering the attacking options the new dribbling system offers, is a beautifully-balanced defence system. Players can use R2 and X to slow an attack, with a double-tap of the X button prompting a perfectly-timed challenge. Full 360-degree control means that players can check runs and steal the ball from a parallel position, while the individuality element will see world renowned defenders using aerial dominance of physicality to win the ball.
Goalkeepers:
Even the game’s ‘keepers benefit from more control, while their distribution is more precise thanks to the addition of a power gauge when they throw the ball, creating opportunities for new, quicker counter attacks.
2. Player ID
Player ID focuses on the individual elements and movements that each player boasts:
Player Individuality:
The very best players in PES 2013 will be instantly recognisable via incredible likeness and signature attributes, skills and tricks that bring them to life. The way they run, turn, trap and move the ball, shape to shoot and even celebrate will be noticeably different during play.
"The way they run, turn, trap and move the ball, shape to shoot and even celebrate will be noticeably different during play."
Individuality to Goalkeepers:
The individuality of movement has also been extended to between the posts. Goal keeping has been totally invigorated via new animations and play styles.
New varieties of saves and reactions have been added to ensure the game’s ‘keepers are in line with the efforts of real shot stoppers. This level of realism also extends to the game’s top-rated goal keepers, with their moves to close attacks down, fling themselves to tip a shot past the post, and in-goal acrobatics benefiting from all new animations and AI.
3. ProActive AI
ProActive AI unites the control and realism, with players that will respond and find space as befits those at the top of their game:
Balance of Play:
The development team has worked closely with the PES fan base to eradicate any illogical elements to the way players move and run in PES 2013, with the ‘ProActive AI’ system enhancing the speed and balance resulting in a more realistic game experience.
Tactical Precision:
The balance of play has also been enhanced in the play between defences and the front line, with greater organisation as the teams track back or pelt forward, setting a harder to beat defensive line, teams adjusting faster to ball gain or loss, allowing for quicker counters.
"The development team has worked hard with real keepers to ensure the AI decision process has been vastly improved."
Enhanced Goalkeepers:
Improvements to the goal keepers was voted the key advancement football fans wanted to see in PES 2013, and the team has worked hard with real keepers to ensure the AI decision process has been vastly improved. Keepers now espond with better reactions, clear their lines more effectively and push the ball savely out of play rather than into dangerous areas.
4. Better connectivity and atmosphere
PES 2013 will also boast better connectivity and atmosphere.
The popular myPES application will extend the connectivity and communication between Facebook-using PES fans, while the game’s audio effects are being tied closer to the on-field action to provide the kind of buzz seen at top-tier matches, with crowds growing in excitement as their team starts to exert pressure.
"The game’s audio effects are being tied closer to the on-field action."
What can you expect in the coming weeks and months?
This article marks the beginning of the announcement of numerous new contents. Gradually, we will get into details until the release of the football game in autumn 2013, and tell you about the new and improved PES 2013 features.
Besides a new look, the official website will also contain new features to enable you as the PES community to meet, talk, and organize with people from all over the world.
If you have not done so, yet, you should also become a fan of the official Pro Evolution Soccer Facebook page. On
http://www.facebook.com/PES, you will never miss any news, events and community happenings.
You can watch new videos on this website, on Facebook, or on the official PES 2013 channel (
http://www.youtube.com/officialpes). Subscribe to the YouTube channel now if you do not want to miss any PES 2013 videos.
Read you soon – stay tuned!
Your PES community team
